Forum Guide - Using the Media Gallery
Forum Media Gallery function
Whilst able to both link to external images and directly embed / upload images as attachments the forum has a useful Media Gallery feature that enables use to save your own album(s), with viewing permission you can set yourself, or to upload into the general forum galleries.
This ensures that images will never expire, allows you to curate to images and allows other users people to rate and comment on them. It also solves problems hotlinks to the various image hosting options out there can cause when either images expire / are removed or hot linking is blocked on the host. (note, we also have hot linking protection set on this forum as well).
A cache (copy) of linked images is made and set to expire after 365 days to cover instances of broken links on all recent posts, however after this time images will be lost (to save site overheads).
At present individual users galleries are set at a 100MB limit which should suffice for hundreds of images, but if that limit is regularly reached it can be raised.
Ideally please try to save images as a smaller jpg. Going from a 3000x1000 pixel full quality .png to a 1000x400 .jpg could reduce an image from 3MB to 150kB for example.
Uploading items to the forum Media Gallery directly
  1. Go to the "Media" section in the main menu (top bar) above.
  2. Click on "Add Media" found near the top right corner.
  3. You will get a popup on where you want to upload the new media. If you just want to put it in your own album, scroll to the bottom.
  4. Click on your album, or "Create new album" if you have yet to create one.
  5. You'll get an option to "Upload file" or "embed media". Choose upload file
  6. Select a file from your computer and click OK.
  7. Give a title and description.
  8. Click Save.
  9. The image will now be uploaded to the Media Gallery and available.
Embedding images from the media gallery in posts
  1. This is simple, just select the camera icon in the post editing window (see the image below).
  2. A popup will appear. Select the source / album.
  3. Click on the image.
  4. Click continue.
  5. You will see the following BB code on the post (spaces added so it will display code):
    [ GALLERY=media, XX][/GALLERY ]
  6. To see how this will look in your post you can hit preview.
